Project 680RR
Aperto da xrmanu, Luglio 15, 2009, 18:54:29 PM
beppoxr65o
In theory having mounted the falicon rod with the xr only bearing kit, you should have solved problems concerning crank reliability...even running the engine higher than 9000 rpm...Crank failure are usually due to the oem bearing rod...it was bad designed: the steel rollers inside are too big, then accumulating a lot of heat, lead to break the bearing cage (too tiny) ...
i'm interesting about how the engine responds with a lighter 102,4 piston!!!  ;D ;D ;D i would compare with my stock 102,4.....just to feel the differences  :P :P...
KAZZEMBERGHER SM TEAM
xrmanu
The gas response is very fast and crisp,just like with the HRC piston.But I have a lighter flywheel and special CDI also. ;)
2Motors ,Erembodegem - Belgium
www.2motors.be
http://www.facebook.com/pages/2Motors/307704402604177
Building unique XR's and other Honda specials for over 20 years now..
What type of CDi you have mounted?
Bye
xrmanu
#108
What Xr's only and other race guys sell/use.  ;)
Citazione di: xrmanu il Agosto 18, 2010, 13:01:22 PM
I had the lighter flywheel and that CDI before - with the HRC piston - also on my bike.  ;D
If I find the time I will make a much larger airbox (maybe in carbon) and a newer, different looking backside on my 680. :-*
www.2motors.be
Phyl
Citazione di: xrmanu il Agosto 18, 2010, 23:55:50 PM
Interesting!!!
Keep us informed!
Il Gabry
Usando il tasto "cerca" hò trovato questo topic con una bellissima moto!
complimenti! veramente spettacolare!
:batti: :batti: :batti:
Using the "search" can I have found this topic with a beautiful bike!
congratulations! truly spectacular!
Il Gabry
xrmanu
www.2motors.be
Your BRP is awesome !!  8)
I think you must work the seat to make it straight.  ;)
Merlo2
