Honda CRF450X with '80s HRC look
Aperto da xrmanu, Marzo 20, 2011, 22:36:45 PM
xrmanu
I sold my XR416 enduro bike last year and bought me something else .... a 450X.I did some modding.  ;)
Custom made sub frame & Akra
Custom grafix
XR400/650 12.5mm euro style break master with (custom made) adjustable lever
Custom case saver:
Base = Euro (plated) CRF450X 2006
Specs & mods:
* engine: - TRX450 steel intake valves
              - matched/ported head
              - 2002 R cam
              - carburetor :R needle, 168 main,48 pilot,Boysen quickshot 3
              - open air box  (top + side plates)
              - Twin Air filter sans screen
              - R header with custom made Titanium Akrapovic silencer (from Yam XTX660) with DB killer
              - pink wire mod.
* frame: - personal ,home made 1 off grafix
             - blue One seat cover "Bailey"
              provided by www.Hells.de:
                - red Racetech plastic kit
                - red chain slider
                - Arc Design precut backgrounds and clutch cover protection
              Acerbis:
-hand guards
                           - skid plate filled with PPI foam
                           - HD chain guide
              - 450R fork clamps with 22 mm offset with Magura oversize     bars with Renthal grips
              - Merge Racing rising rate "woods" springs
              - Zeta fork bleeders
              - custom made laser cut HD case saver
              - 19" R wheel
              - 14 x 51 gearing ,gold colored RK low friction O-ring chain
              - red wheel spacers
              - Ufo Plast rear/stop light (led)
              - Trail Tech Vapor with billet holder
The inspiration:
the true RC500M works bikes from the '80 s ...  :worthy:
2Motors ,Erembodegem - Belgium
www.2motors.be
http://www.facebook.com/pages/2Motors/307704402604177
Building unique XR's and other Honda specials for over 20 years now..
wonderful bike ;   Manu you are a great !!!!!!!!!         the xr and now the crf are very very very beautiful .
I'm happy you write in this forum . Ciao Manu !!!!!!!!!!!!!!!!!!!!!!!!!!
very nice bike, and very nice friend!!!  :) :) :)
Cako
 :applausi: :applausi: :applausi: :applausi: :applausi:
Very good!!!
You have only wanderfull bikes  ;D ;D ;D
xrmanu
Thx guys ! :)
This the "old" white version...
And something in between...  :P
www.2motors.be
mauro981
JJ
xrmanu
Update:
Super-B Battery Relocation
1648gr lighter ,lower center of gravity ,a lot more cranking amps and 2 times the flow to the air box .I have put a 1 size larger main in the carb as a starter and it was definitely worth it handling/power wise...
For the sceptical: No or minimal rocks over here,minimal water crossing and good protected/sealed battery poles/cables,no heat transfer from the engine.
More here:
http://www.facebook.com/media/set/?set=a.406318422742774.85533.307704402604177&type=1
www.2motors.be
Phyl
Noooooooooooo......
I can't believe it......... i've never seen a battery so light and put in that position!!!!!!
Very Good!!!! :) :) :)
buzdesign
tagliaerbe
splendida....anche bianca è molto bella...
Citazione di: Phyl il Giugno 19, 2012, 08:12:28 AM
Noooooooooooo......
phil i can't believe you're so noughty pupil...  :D :D :D
http://www.xr-italia.com/forumxr/index.php?topic=18010.msg410906#msg410906
http://imageshack.us/photo/my-images/542/21122011252.jpg/
Phyl
Ecco ........ lo sapevo .......... hai rovinato tutto..................... era per dare + soddisfazione a xr manu .........
P.S.: però tu la batteria l'hai messa in alto, indipercuihaialzatoirrimediabilmenteilcentrodigravitàconconseguentediminuziodell'agilitàdiguida!!!!!!
Tiè!!  :beffe:  :D :D ;)
manu e' un bravo ragazzo... :) :) :) non vorrei mai togliergli soddisfazioni! ma... guarda che come ce l'avevo prima la batteria da 2,5kg oltre a dare problemi di agilita' di guida dava anche problemi di stomaco!!!  :D :D :D
